Loading...
Quick Links
Duration and scheduling
Home Forums Discussion Duration and scheduling
Viewing 9 posts - 1 through 9 (of 9 total)
  • #5109
    Avatar photoCommunity
    Keymaster
    When a duration of a task is 1 day, MS Project and the task has dependency and on Auto Schedule, MS Project is not consistent in the way it has the Start date and Finish date. Example:
    Task Name Duration % Complete Start Finish
    Task 1 1 day 0% Mon 4/2/12 Tue 4/3/12
    Task 2 1 day 0% Tue 3/6/12 Tue 3/6/12
    How can you Fix this problem and make it Start and Finish Dates in a consistent manner (Task 1 or Taks2), and why is it MS project doing this?
    #6763
    Keymaster
    I think Task 1 is starting some time later than 8 AM on 4/2/12 ( assuming standard settings).
    Insert the Times along with dates, and that should give you a clue. (File >> Options >> General >> Date Format)
    #6765
    Keymaster
     Posted by Asim AnsariWhen a duration of a task is 1 day, MS Project and the task has dependency and on Auto Schedule, MS Project is not consistent in the way it has the Start date and Finish date. Example:
    #6766
    Keymaster
    Here is what I found ,
    When you want the task to finish the next day, go to options , set the defualt from 8:00 to 5:00 , eneter 9 hours per day , enter 45 hours per week, enter 20 days per month , next go to the calendar , enter 8:00 to 12:00 then 1:00 to 5:00.
    otherwise the task will end the next day .
    Cheers
    #6767
    Keymaster
    Sorry Correction
    When you want the task to finish the same  day, go to options , set the defualt from 8:00 to 5:00 , eneter 9 hours per day , enter 45 hours per week, enter 20 days per month , next go to the calendar , enter 8:00 to 12:00 then 1:00 to 5:00.
    Cheers
    #6769
    Keymaster
    Rick has the right approach to start with.  I wouldn’t change the calendar for the sole purpose of attempting to land a one day task on the same day.  This will have consequences throughout your project.
    #6771
    Keymaster
    Hello Asim,
    I can’t reproduce the issue. Have you updated the product ? If possible, pls send me the mpp file and a snapshot of the screen at projectuser[at]fastmail.fm. I’ll check and post feedback.
    Regards.
    #10522
    Keymaster
    You might want to check you default calendar settings to make sure you are working standard hours (8 AM to 5 PM).  I would also suggest checking your project options to toggle the task type between fixed work and duration to see if that makes a difference.  If neither of those fix the issue, then I would suggest looking at the details of each of the two tasks to see if the settings are the task level are different (ie one is effort driven, one uses a different calendar, etc.).
    #10523
    Keymaster
    A strong possibility is that somewhere in your path one or your tasks has more or less than an 8 hour day.  These can push part day durations to later tasks due to your dependencies.
