Extending project duration
Home Forums Discussion Forum Extending project duration
    • #2154
      Hi there,
      My current project duration is 2 years, but I need to extend it to 2,5 years keeping the same information. Is there a simple way to do it and have all the tasks and sub tasks extended proportionally?
      Thanks a lot!
    • #6542
      Sorry there is not a way to do what you need.  What you would need is a function that would add a percentage of work and duration to each task and that doesn’t exisit.   You should manually go through the project and extend the tasks that should be extended.
    • #10225
      Thanks Ellen. That’s not the answer I was expecting, but if that’s the case I’ll have to do it manually.
    • #10226
      You can easily do this with a little help from Excel. Following instructions are on Office 2007.
      (1) Copy only the duration column to Excel. (Gantt chart view-> Right Click on the Duration column heading -> Copy Cell)
      (2) Paste on an Excel sheet.
      (3) Extract the number only. In Excel sheet select Data -> Text to Column -> Delimited -> Delimiter is space
      (4) Apply you formula and get new durations
      (5) Paste new durations back in MS Project.
      Isnt it cool!
    • #10227
      Thanks! That’s a great idea. It didn’t solve all my problems, but it did save me a lot of time a work. Actually, it is very cool!
