Loading...
Quick Links
Gantt Bar Heights Will Not Change
Home Forums Discussion Gantt Bar Heights Will Not Change
Viewing 4 posts - 1 through 4 (of 4 total)
  • #477364 Reply
    cbass1224
    Hello, all. I cannot get bar heights to change on screen in Project Professional 2016. It seems to be a problem with my laptop. The bars will change in the same files opened on other computers. All of them running Windows 10. Has anyone had this problem? What is the cause/fix?
    Thank you!
    #477392 Reply
    Jigs Gaton
    hi class, 2016 had a lot of graphic bugs, so first u should check and make sure you are at the latest release level for that version. It that does not fix it, there is always a complete reinstall of MSP. If that does not work, well, there is MSP 2019, which works great in Win10. Cheers, Jigs
    #477412 Reply
    cbass1224
    Thanks. I have to work with company IS to try to get it fixed. We tried repairing the App but that didn’t work. I’ll see if I can find out if there’s an update available.
    #477417 Reply
    Jigs Gaton
Reply To: Gantt Bar Heights Will Not Change
Your information:
