Master/sub project deliverable problem
Home Forums Microsoft Project Discussion Forum Master/sub project deliverable problem
    • #4982
      Community
      Keymaster
      Hello all,
      I’m working in a master project with multiple (4) sub-projects.
      I’ve established deliverables in each sub-project and the master.
      I’ve synced the deliverable first in each sub-project and lastly in the master.
      Only the master deliverables appear on the sharepoint site.
      I thought I’d check here before I manually enter several deliverables.
      Any advice?
    • #6371
      Community
      Keymaster
      Hi Patricia —
      I assume that since you’re asking about deliverables and SharePoint sites, you must be using Project Server?
      If so, then each project in the system has its own separate Project Site for tracking documents, issues, risks, and DELIVERABLES for that particular project. This includes master projects as well, so if you have a master / program schedule with four sub-project schedules, then you will ultimately have FIVE separate Project Sites… one for the master and one for each of the sub-projects (assuming that your system is configured to auto-provision Project Sites).
      That being said, the deliverables that are published from each project will be stored in each project’s respective Project Site, and they WILL NOT be automatically aggregated into the Project Site that is attached to the master project. If you want all of the sub-project deliverables to appear together in the master’s Project Site, then you will need to custom develop a solution that does this. There ARE options for doing this, but they are too detailed and technical to describe here. If you would like help with this, then please feel free to contact me directly.
      Good luck!
      Tony Zink, MCTS, MCITP, MCT
      Director of Client Services
      EPM Architects, Inc.
      Web: https://www.epmarchitects.com
      Blog: https://www.epmarchitects.com/blog
      Twitter: https://www.twitter.com/epmarchitects
    • #6376
      Community
      Keymaster
      Thank you! As you explain it, it makes total sense to me.  We are aggregating everything up to the master.
      I’ll pass the info on to my Project Server admin and let him decide what we do.
      Thank you again for your help!
    • #6390
      Community
      Keymaster
      Tony,
      Would there be any negative (i.e., buggy) consequences to pointing more than one project to the same Project Site?
