MS Project 2016 Professional – Change Template Listing Layout
Home Forums Microsoft Project Discussion Forum MS Project 2016 Professional – Change Template Listing Layout
Viewing 0 reply threads
    • #413969
      Kevin N
      I manage projects across three product lines, for simplicity let’s call them A, B, and C. I have specified my template location in Options/Save/Default personal templates location. In that location are folders for each product line that contain as many as 50 templates each. When I open File/New/Enterprise I see each of the three folders in the typical Icon/Tile layout, and I see my templates when I open each folder. This is all well and good. However the template names are truncated, and unless I right click and “Preview” the template icon I cannot see the full name. Many of the names start with the same verbiage, so it can be an iterative process to select the correct template. Is there any way to change the layout from the tiled to a list format, showing the full names of the templates?
