Home › Forums › Microsoft Project Discussion Forum › MS Project for Program Management
Tagged: Microsoft Project, project managers, resource pool
About seven years ago the state government IT organization that I remain employed in decided against a Microsoft EPM solution implementation because funding was not available. As a work-around to support scheduling multiple projects that needed to be integrated into a five-year IT improvement program (ITIP) in planning at the time, I turned to Project Pro 2003.
Each scoped ITIP project required a set of three to four supporting schedules necessary to do the following:
Each set of project schedules for each institution was inserted into an institution master schedule to support IT campus level management. Additionally, each institution master schedule was inserted into an ITIP master schedule to enable centralized, highly flexible sequencing and compression of schedule elements across all institutions in the program. Such scheduling made complex cross-project dependency setting and integration possible among all site survey projects and among each of the several other recurring project types.
If I had it all to do over again, I would have also created and maintained a resource pool schedule using Project Pro, and would have assigned project managers and all other program resources from the pool in order to take advantage of the software’s more advanced human resource management functionality.
