Home › Forums › Microsoft Project Discussion Forum › MS project integration with Oracle EBS
Is there anybody who uses MS Project with the Oracle EBS Project module ?
We would like to extract cost data from MS Project and send it to EBS for billing.
Thanks.
Claude Lamy
Quickbooks 6000 77 occurs when you are trying to open the company file. There are many reasons to occur this error- this error can occur when you are using Quickbooks in multi-user mode when your .tlg file gets damaged, when the installation file of Quickbooks is missing, etc. There are solutions to solve this error, you can check it by clicking on the URL.
You can impede your work with Quickbooks error 6189 and 816. It occurs when you use a multi-user network device to access the company file. Access to your company file is restricted due to this run-time error. A fatal error has occurred accessing the company file (6189, 816).
What Can I Do To Fix Quickbooks Error 6189 and 816?
1- QBs should reboot their systems and servers
2- Quickbooks Desktop updates
3. Move the company files to the C drive
4- How to use Quickbooks Software Tool Hub
You can also check this solution to integrate any système with ms project.
Kind regards
