Home › Forums › Discussion Forum › Resource Filter applies automatically when opening file
I have modified soemthing in Project 2003 that causes the “Resource” filter to open automatically during the file open sequence. I’ve checked all views for an errant use of this filter and can’t seem to find anything that is calling for this filter. Does anyone have any suggestions? Thank you!
Dee Anderson
Dee, strange behavior that I haven’t seen before. Can you provide a bit more information? What filter gets open? I’m assuming that you mean the filter edit window opens. If nothing else works you might try to repair the program. I don’t have 2003 installed but for future releases you can repair by going through the Control Panel, Programs and Features, and select Change.
Dee,
There is a Detect and Repair icon on the formatting toolbar, that might help.
Thank you Jack & Larry! I did try the repair and even reloaded Project. It still persisted, but it made me realize the problem was in the project file and not the global since new files did not have the problem.
I started trying to repair using resource” filter, but didn’t work because it is non- modifiable. Then copied a couple of custom filters from an older version of the file. It was in a custom filter even though I was not using it. Bizarre.
Thanks so much for helping me to get there. I do appreciate your help!
Dee Anderson
Hello Dee,
If you are still interested in fixing the issue, you can send me the file at projectuser[at]fastmail.fm. I’ll try to fix it and get back to you as soon as I can.
Rgrds.
