Loading...
Quick Links
Timeline Timescale setting in Project 2013?
Home Forums Discussion Timeline Timescale setting in Project 2013?
  • This topic is empty.
Viewing 5 posts - 1 through 5 (of 5 total)
  • #66752
    Sheryl Pass
    Does anyone know how to scale the timeline to show a specific date range?  I located a post (http://answers.microsoft.com/en-us/office/forum/office_2013_release-project/timeline-timescale-setting-in-project-2013/06e104c1-5de8-4b8a-bbdf-fa4613f0fd88?auth=1) that says:
    The Timeline shows the entire project from start to finish date – even if you don’t have tasks added to the timeline.
    I can reproduce what you report and cannot seem to find an elegant way of changing the formatting short of changing task durations and forcing a re-paint of the timeline scale.
    Am I missing something?
    #71057
    Ismet Kocaman
    Sheryl, No. It is not possible to change the range preset. Regards, –Ismet
    #415873
    Ian H
    I realise this is an old post but in case anyone else reads it and wonders:-)
    You can change the date range by clicking on the timeline date line, then going to Format > Date Range and input the range you want to show.
    #417182
    Amanda K
    In response to Ian’s post, the option to adjust the timescale of your timeline is only available in the Project PROFESSIONAL version, and not in Standard. I have been doing extensive research trying to make it work and have decided to just create a custom timeline in MS Excel to suit this particular need.
    #418002
    Walid A
    I have Project professional, and I am able to set the date range for a specific timeline. The problem is that I can only do that for the first time. It doesn’t allow me to change the date range a second time for the same timeline (the button is grayed).it seems it’s one-time change that cannot be edited again. Anyone know the solution?
