I am planning a project that has efforts happening in multiple locations at the same time and I want to be able to review the work happening in each location at any time.
What is the best way to set up the locations? Should I set up the locations as resources, use a WBS (which doesn’t feel right, but may be an option), or use a text field?
There will be other resources planned, equipment and work, and I do have a WBS available for the work discipline already established.
Thanks!
Hi Michelle! Yes, I use custom text fields all the time for this purpose; works great. A resource can be identified by country or department easily this way, and then you can sort and filter on that field to your heart’s content. Cheers, Jigs
