Home › Forums › Discussion Forum › where is the ‘entry’ bar in Project 2010?
Tagged: entry bar, In Microsoft Project 2007, Microsoft Excel 2007, Microsoft Project 2010, spreadsheet
You edit right inside the cell in 2010. You can place your cursur over the cell and click to edit.
Ginger
hanks ginger… i knew you could do that, but it takes a few clicks to activate the cell… i gues i was just searching for the way i’ve navigated in msp for the last 15+ years… 😉
Laura
You can show the entry bar. Go to the ‘File’ Tab then click ‘Options’ then Display. At the Display screen you want to check the box for ‘Entry Bar’ under where it says ‘Show These Elements’
Gene
wonderful!!!! thanks so much. 🙂
Laura
You can also use the “F2” key to place you into edit mode on the task description. When updates are complete, hit the enter key and you will be out of edit mode.
Steve
