Loading...
Quick Links
2007 and 2010 Cube
Home Forums Discussion 2007 and 2010 Cube
Viewing 2 posts - 1 through 2 (of 2 total)
  • Author
    Posts
  • #5147 Reply
    Community
    Keymaster
    What does “Assignment Timephased” and “Non-Timephased” mean exactly?
    #6826 Reply
    Community
    Keymaster
    In general terms, timephased means that the cube allows you to see data by time.  A non-timephased cube does not.  In other words, the assignment non-timephased won’t give you the ability to see assignments for the month of May, but it will allow you to see all assignments for a particular project or resource.  The non-timephased version is a much smaller cube and more performant than the equivalent timephased version, so if you don’t need show or filter by time on your report than you should use non-timephased.  Hope that helps.
Reply To: 2007 and 2010 Cube
Your information:
79 − = 73
