Custom field formulas
Home Forums Microsoft Project Discussion Forum Custom field formulas
    • #397056
      Ramil Ganiyev
      First of all I would like to thank to everybody for their answers, feedbacks and help.
      I made up 2 formulas in custom field which work fine in separate mode. However when I trying to use AND / OR function in formula in order to use both calculation the system gives error.
      Here is the example
      First calculation ([Number11]-[% Work Complete])/25*44
      Second calculation ([Number10]-[% Work Complete])/60*44
      When I edit formula with below 2 options the MS project gives error.
      ([Number11]-[% Work Complete])/25*44 AND ([Number10]-[% Work Complete])/60*44
      ([Number11]-[% Work Complete])/25*44 OR ([Number10]-[% Work Complete])/60*44
      Could you please advise which WORD or function I should use if I want to MS Project calculate info from 2 different column.
    • #397063
      Tom Boyle
      Hi Ramil,
      I think the And/Or operators require a Boolean value (True/False) on each side, but neither of your functions evaluate to a Boolean. You need to add an evaluation criterion to to each of them (like “=1”) just to start.
    • #397077
      Ramil Ganiyev
      Dear Mr. Boyle.
      Thanks a lot for your reply.
      May I kindly ask you to write down full formula by using “-1” which your mentioned above.
      Your help and support are appreciated
    • #397082
      Tom Boyle
      Sorry I can’t provide a formula because I have no idea what you are trying to achieve. You must explain a little more.
