Home › Forums › Discussion › How to add and remove a subproject into a master project in MS Project 2007 to show on Project Server reports
Tagged: mater project, Microsoft Project 2007, Project, project plan, subproject
1. Open up the intended master project plan in Project Professional 2007.
2. To add a project select insert> project (and then locate the file). Afterwards save and publish the master project onto Project Server. This will make the subproject a subproject on the server. (Please be aware that you are currently unable to run highlight reports on subprojects).
3. To remove a project plan (and thereby make it a normal project), select the project task from within the master project plan, view task information and then on the advanced tab de-select the check box to “Link to project”. Save and Publish the master project to make the update to project server.
4. Doing this should reinstate your subproject as a normal project – and allow you to run reports on it!!
-Ryan Lynn
For 2007 make sure you have SP2 installed and ALL hotfixes as some master project bugs are still being addressed. Patches have to be on server and client.
I’m a newbie here. I don’t know much about it. I hope someone might help you here. All the best!
In the contest, you will need approval to view live content or screens on ESPN-triggered Roku streaming devices. In addition, there are many channels through multiple streaming solutions such as sports screens, live broadcasts and much more. These are all the situations you will encounter on espn activate.
It looks like a good guidelines. Thank you so much for sharing.
In addition to the other comments; all sub plans and the master plan must be stored in the same folder.
Saving Cents Together provide different Promo, Coupon Codes for brands of all categories you can avail them and save your money on items
informative post really helpful
Keep sharing helpful posts.
Your post is really helpful if you need any printing or packaging service please visit us: https://impressionville.com/
watch live football match at
http://www.tvxoilac.com/
